How to Correct Camber on Front End?
Hey Folks,
I could use some advise...
I have changed out my struts and mounts on the front and rear end with KYB parts. Everything went well but will need some front end alignment, pulling to the right at times and sometimes not pulling at times. sometimes it tracks very good on different road surfaces.
I would like to know if there is adjustment for camber? I am wearing the inside of one of my tires on the left driver side. I didn't know if a regular front end alignment would correct it or would I have to change out some other parts that may be worn to correct. It has alot of miles 220,000 plus..
my suspension is stock, no lowering..
thanks for your reply..
jon
jon
Last edited by hcfarm; 10-03-09 at 07:19 PM. Reason: clarification of stock condition for suspension
Yes you can adjust camber with the bottom end of the strut. There is slack when the bolts are loosened. I think they have offset bolts for the bottom end of the strut too.
Carguy- Don't know what happened to the other posts on this thread but somehow disappeared. Have you ever had the front struts off of an early RX? I have had 1 off of my Dil's RX and there was NO adjustment at all, in spite of the fact the manual says there is a small amount. Those huge bolts fit precisely through the holes. Just curious what your experience has been.
No, I have not personally had a strut off of the RX so I'm not sure about the slack thing. The factory manual says it's there, but I did not see it myself. I have had a Camry apart and the eccentric bolts were already in there. I think the suspension is basically the same stuff.
In post #6 it looks like someone got some slack, but I think eccentric bolts are needed to make any real changes.
https://www.clublexus.com/forums/rx-...ujustment.html
