how to run power to the trunk?
I need to run 2 small power cables to the trunk of my 2000 rx and was wondering what the easiest way to do it is, I cannot use the accessory plug wiring, it has to be from the battery itself!
Im looking for the simplest way.. 2 very thin small wires
any ideas?
Pat
any ideas?
Pat
I think the easiest way would be exposed, on the underside of the car, tie-wrapped to prevent movement and damage. The best way, however, in my opinion, would be via the interior, under the carpet.
Make sure you put an in-line fuse in near the battery.
Do you have an electrical snake?
If they are small power cables, why do you need to tap in directly to the battery?
Eds98LS
06-20-13 05:05 PM
Kawai4eva
RX - 1st Gen (1999-2003)
01-14-13 01:55 PM
