Aftermarket Stereo for '02 RX300
There is a company called metra that makes aftermarket radio kits for first gen rx300s that are touch screen but tie into the factory look and give you full climate control.
https://www.youtube.com/watch?v=kdGf4ZND-cM
I've been looking over this forum thread and haven't seen the answer to my question, although I've seen references to it (and the few links I followed from those references were either dead links or reached irrelevant solutions). I have a 2003 RX300 with 240K comfortable miles on it and the "upgraded" Nakamichi-sourced OEM stereo. It has an AM/FM /Cassette with a 6-CD changer in the glovebox. I've been using a $5 cassette adaptor for the last 10 years to provide an AUX input for my $20 eBay MP3 player, which has worked great, until the other day when my cassette deck ****-to-bed. Now all it does is click a few times and then eject the adaptor, but will not play cassettes or allow the adaptor (therefore the AUX input) to remain in the playback loop.
I really like the sound of the stereo and have no desire to "ugrade for better sound quality" (not to mention that the AC controls are integrated with the radio controls in the dash so I'm really in a tough spot in that regard anyway). So I'm looking for a solution to keep the factory interface and stereo system intact. I've heard about "AUX-upgrade hacks" for this unit, which would seem like an ideal solution for me. Can anyone point me to a simple method to allow me to add an AUX output to this unit? Thanks!
MasonFX (07-07-23)
I will add here that all the solutions I've seen refer to the OEM stereo but NOT to the Nakamichi unit, which is considerably better-sounding imho (and is more tightly integrated cosmetically with the factory AC controls), and I have NO desire to replace anything about the stereo I have except to add an AUX-input solution.
I can agree with you if it works correctly as i have both stacker in dash and glovebox and it sounds great the only issue i have is stackers have problems and never stop changing dash discs so it is a power drain as still does it with keys out. I have upgrades to adapt things stacker socket splitter with aux in. The fantasy is it has acceptable sound to amplify as in reality may not be as good as what your starting with.
Did you end up installing it? Did you have to do the amp bypass way in the rear and run speaker wires back up to the headunit? Or does the included amp bypass plug in somewhere behind the radio?
So I bought a second 10'' from another supplier as was lied about features from first and it turns up broken. I am so fed up that i will sing like a canary if I don't get a satisfactory response. The unit is broken arrived with the mounting clips snapped off. Which are on the unit itself the expensive part. I am rightfully pissed off right now as it looks like it could have been avoided if supported correctly packing.
They have kept playing dumb i will highly advise others to keep their money over buying these. i was purposely sent broken equiptment as they left screws out of it to try to validate the damage i suspect they only have broken units to send. Another member had same issue.
