Scan Gauge II
Scan Gauge II
I just purchased a Scan Guage II to use on my 2002 RX 300.
Has any other forum member purchased and installed this Scan Guage in a similar year RX?
If so where did you finally wind up mounting the reader? (I cant find a good place to mount it so I can glance at it while I drive , the whole dash is taken up with other equipment and guages)
What has been your experience with the Scan Guage?
Has it lived up to your expectations?
Any input would be appreciated.
Thank you.
Thank you.
Super Moderator
I can't comment directly, but I know there is someone I think either in this the 1st gen or the 2nd gen forum who has installed the scan gauge, which is an exceptional tool in it's own right. I've considered it, but am leaning toward either a laptop or advanced OBD2 scanner (still haven't made up my mind, though I now have the $$$).
I swore from what I remember about people installed it in similar 1MZFE vehicles (Solara, Camry, etc.) they mounted it somewhere along the bottom of the instrument panel.
Thank you.
Thank you.
P.S. SG does sell a mirror mount (I think made by someone else) that might be an answer for you if you're not into custom fabricating.
Lemex, Code 58...
Thanks to you both for your input.
I have only had the Scan Guage a few days so I'm still trying to understand it's operation.
I will consider you suggestions on a mounting location. I would like to mount it in a location where the cord to the OBD II connection is not so visible.
I am going to continue looking.
Lemex, Code 58...
code 58.
Thanks for your input.
Yes, I have seen the mount that SG sells to mount the guage above the mirror.
I think trying to run the cord under the headliner and down the windshield post is a little more work than I am willing to undertake at this point.
I might do as you have done and see if I can fabricate my own mount.
I am going to try to find a spot somewhere on the dash or maybe for now just leave it where I have it mounted (just to the left of the steering wheel right above the mirror control, security monitor, and seat memory feature) It's not the greatest place for the guage but it might turn out to be the only place.
Thanks again for your advice.
dchan865
RX - 4th Gen (2016-2022)
08-17-18 12:23 PM
