Help with couple of issues
so i tried to do some work on the truck but i can't figure this out, i don't have a good view of what at doing resulting in me not trying harder because i don't want to make it worse.... i'm attaching a picture (a lexmex original picture), i have marked in red the holes that i'm using and in green the missing bolt, i don't want to go to the shop to get this fix because i don't wanna have missing bolts or clips or my door panel all greased up plus i know with the right guidance i can do this...........
hey i don't want to be a pita but i also have the driver's side seat belt somewhat worn out, can i cut the part and glue it back or is there a better way to fix this?
Super Moderator
With the seatbelt, there was a trick I did a few years ago using a very thing double sided tape that I attached to the belt and pulled through the area where it loops through in order to clean it. I've also taken a razor to that loop to scrape off the black muck that's there.
I'm still having an issue with your door thing even after looking at it. I just can't get fathom what's actually occurring for you.
nevermind peoples fixed it...... i bought the missing bolt, thing is a thought the part was supposed to hook somewhere but is either broken or it doesn't hook anywhere, so I pushed up and bolted it to the door..... thanks anyways code58 and lexmex
billy boi
25
08-13-05 08:09 AM
