Brake light, works for braking, but not for running lights
Old 12-19-09, 08:59 PM
SethP
SethP's Avatar
Default Brake light, works for braking, but not for running lights
Anyone seen this before? The bulb is brand new, it works fine if you hit the brake, but not if you the lights are just on. The other brake light/running light works fine, it's just on this one side.
Old 12-20-09, 07:04 AM
bob2200
bob2200's Avatar
It sounds to me like maybe a dual-filament bulb. Check that the wire contacts on the bulb aren't bent out of position. Also, switch right and left bulbs to eliminate the chance of a burned out filament being the problem.
Old 12-20-09, 09:04 AM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Tail light and brake-light have different filament, encapsulated in one glass shell. Tail light should light up on the first stop of the light switch and the brake lights light up when you press the brake pedal.
Both the tail light and the brake lights are independent of ignition switch position. [not in every car, but yes in Lexus line]
For replacement, match the wattage, else the light out sensor will trip.
Wiring/bulb confusion stems form an ingenious implementation of switching on/off the brake lamp as a turn signal [I term it the American no-yellow turn signal]. The trailer wiring hitch for Lexus needs that conversion as the trailers use the same bulb for brake and turn.
Salim
Muffin123
03-30-19 08:48 AM
Mystik
08-27-15 06:57 PM
JSC4
06-18-13 05:34 AM
pitmanr200
09-16-08 09:32 PM
blkstealthpaid4
10-12-01 03:42 AM
Quick Reply: Brake light, works for braking, but not for running lights
