Burning rubber smell in Reverse?...
Old 01-07-10, 03:52 PM
Privacy
Privacy's Avatar
Default Burning rubber smell in Reverse?...
my car shifts great and runs awesome as the day I got it
but when I shift into reverse I can smell a burning rubber smell, there is no problem or hesitation, just a burning rubber smell...
what could this be?
no CEL lights
its been doing this for a few months
only when in reverse
car is smooth as could be
smell comes through the a/c system, and when i stop the car from under the hood
no burning oil, no sludge, no problems at all
Old 01-08-10, 06:19 AM
ByTor
ByTor's Avatar
Mine smells like that all the time. No CEL, or any driveability problems either. The smell does not come through the A/C, but you can smell it when you get out of the car.
No clue what it is either.
Old 01-08-10, 07:26 AM
lexus114
lexus114's Avatar
Burning rubber smell in reverse huh? that one beats all.
Old 01-08-10, 07:45 AM
Lexmex
Super Moderator
Lexmex's Avatar
I'd try to have someone outside the vehicle pinpoint the smell when you put it in reverse.
Old 01-08-10, 08:58 AM
sktn77a
sktn77a's Avatar
After you smell it in the car, remove the transmission fluid dipstick and see if it smells burnt - unlikely, but hey, this is a new one!?
Old 01-08-10, 11:43 AM
Privacy
Privacy's Avatar
tranny oil doesnt smell burnt..
i have tried with people and they cant pinpoint the smell
no clue what it is
its not strong but you CAN smell it...
only comes through the a/c when the air is NOT set to recirc so it pulls in the smell from the engine area naturally...
Old 01-08-10, 12:41 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Little out of the box thinking here ...
Maybe the smell in reverse has to do with the movement of observer ... the source is always there, but it is sensed as the observer moves in the path.
To eliminate the above ... how about engaging the reverse gear and with the foot on the brake; go nowhere.
Or better still:
Have the RX on lift and check with wheels turning in reverse.
Salim
Old 01-08-10, 01:17 PM
Privacy
Privacy's Avatar
i just tried that actually...handbrake on..in reverse....you can smell it yes...very faintly... it doesnt do it in drive..just reverse...
Old 01-08-10, 10:24 PM
Privacy
Privacy's Avatar
figured out what makes it do the smell..anytime the rx is on any incline up or down more then a few degrees I get that smell..what could that be?... Its from the engine bay area.
Old 01-09-10, 01:11 AM
Nad1370
Nad1370's Avatar
Could be your reverse band in the tranny thats starting to slip but not felt when driving in reverse.
The highest psi fluid flow in the transmission is in reverse. therfore even though the smell isn't coming from the fluid itself but probably in the vent tube of the trans.
Hopefully this is not the case and you just have a lot of power to the wheels and your roasting your tires. Lol
Old 01-10-10, 02:10 PM
Privacy
Privacy's Avatar
lovely..
I was hoping that would not be the case, I was hoping that the car would last 200K or at least 150K on the stock tranny...
Now here is the interesting part, The other day I parked my car on a hill facing down so the back end of the car is up and the front is down..and put it in park..left it running for 5 minutes...and I still got the smell.
What could that be?...on level surfaces, I get nothing smell wise and it drives like a dream regardless of terrain or incline
Old 01-11-10, 05:41 AM
thomas1
thomas1's Avatar
Mine is having the same issue after some hard driving...does it on level. I guess it will rear its ugly head sometime. I cant quite understand the rubber smell though..I thought the bands had more brake type material on them.
Old 01-12-10, 03:54 PM
hypervish
hypervish's Avatar
Have you drained and filled your differential lately? It's not that costly and its worth a shot to see if it will stop the smell.
Old 01-12-10, 03:55 PM
Privacy
Privacy's Avatar
yes, i got all new fluids about 4K miles ago.. and new oil 2K ago
Old 01-12-10, 03:56 PM
hypervish
hypervish's Avatar
What weight did you use?
Quick Reply: Burning rubber smell in Reverse?...
