Help! Wood Trim on Doors
Whats up guys,
I noticed in an earlier thread that the wood trim on the center console is easily removed by a screwdriver because it is only held on by clips. I was wondering if any of you guys can help me with the wood trim on the doors. I recently damaged one of them and was looking to replace it. I am hoping that the door trims are held on by clips as well so can I use a screwdriver to remove the door trims as well? Does anybody have info that can help me? Thanks.
Hi Leebro3,
The wood panel on the doors are easy to be removed.
Use a screwdriver, remove the panel slowly from the top (facing front of vehicle). There's one clip in the front and another in the rear. After you un-clip the front, the rear should just pop out easily.
My scanner is not working at the moment, otherwise I'd be happy to scan you a picture from the manual.
Good luck!
Hendry
Good luck!
Hendry
hendry,
shoot me an e-mail when you get a chance.....wannna ask you a couple of things
thanks
shaonuff@hotmail.com
thanks
