RX300 1999: To Flush or Not to Flush?
Some folks say that you should never get a tranny flush on a RX300 1999 AWD. Others say you better do it every 15K.
Some say if you do decide to flush, don't bother taking it to a dealer, take it to a good mechanic and save $$. Others say always take it to a dealer or suffer the consequences.
Thoughts? Experiences?
I'm not aware of anybody saying to flush every 15,000 miles. Perhaps you are confusing a drain-and-refill with flushing. Don't flush, do drain-and-refill.
I think the risk of taking it to an average mechanic is that, basically, you must use Toyota/Lexus transmission fluid. This is not something the average mechanic has on hand, and using normal automatic transmission fluid could be a disaster.
Boy, do I feel foolish.
But I might get a new tranny out of it, paid for by the insurance company of the oil change place
I had my dealer flush mine at about 120K, just because I trust them and I don't know that it had ever been done to the vehicle before. They recommended keeping the original metal filter screen, not replacing it with the replacement paper element. No problems so far....
My dealer just drained and filled my transmission at 30k and 60k. At 90k they flushed with their "special" Lexus transmission flush equipment but didn't change the filter (they have never dropped the pan). Now, (130k) they advise against flushing - just drain and re-fill.
Go figure!
Go figure!
My thought is that one good flush at 90K or so might be a good thing; after that, I'm hoping an occasional fluid change will keep things going as long as we have the vehicle.
I did a flush around 82k when I first got my RX, after about 6k after I dropped the pan to clean the magnets, and see the condition of the filter. The screen filter I tried to clean most of the metal fillings out, but since you can't get it all out, I believe you can still order the screen filter from toyota/lexus I just don't know the part #. Also, even after this "flush" with toyotas "special tranny flush machine" there was still a gray milky residue on the bottom of the tranny pan and the magnets definately needed a cleaning. While I was on there cleaning it out i through in 3 more magnets to try and prevent tranny failure. The only thing I think the "special tranny flush" is good for at toyota is the completely evacuate the old fluid with new.
2MCHPSI
RX - 1st Gen (1999-2003)
01-01-06 03:00 PM
