Steering wheel making noise when turning
Old 04-10-11, 07:51 AM
imherenow
imherenow's Avatar
Originally Posted by Barnacules
Dude... You are forum Jesus to me! I have had my RX300 for over 5 years and it has made this sound since day 1 and has got worse over the years. I found this forum because I wanted to finally post a video I took of the problem to see if someone found out what the heck was going on. Without even posting the video I found your suggestion and went out and sprayed it with WD40 right under the steering wheel and after 2 turns... BOOM!... Noise gone, nice a quiet. Man I wish I had of found this forum 5 years ago Here is the video incase anyone else needs to understand what noise this solution solves.
Did u searched the forum before???..there are tones of it under RX 300 model forum that owners had problems with squeaky steering wheel noise and was solved with simple silicone spray. But good to know u have no more problem
Old 12-14-11, 05:19 AM
thug9030
thug9030's Avatar
thanks I just used the wd40 and no more noise
Old 12-06-12, 01:59 PM
chococat
chococat's Avatar
I just had to say a quick "thank you". That video was perfect. My 2000 ES300 has been making that silly noise for years. I just tuned it out. Actually came to this forum after google searching squeal for power steering pump. This little gold nugget was just a serendipitous find. So thank you!!
Old 12-23-12, 02:46 PM
Lionorion
Lionorion's Avatar
Originally Posted by yeuemhoai
This is where I put silicon spray and the noise has come back after 3 years.
Thank you! Two squirts, and the steering is silent! Awesome! :-)
Old 02-16-13, 05:56 AM
2KHarrier
2KHarrier's Avatar
So, just to make sure I understand, I'm spraying the lubricant where the steering shaft goes through that dust boot at the base of the fire wall? I was thinking of spraying between the wheel and the plastic housing around the steering column?
Seems like an easy fix....
Sa-weet!
Old 02-16-13, 08:20 AM
salimshah
salimshah's Avatar
Received 1,069 Likes on 962 Posts
Sa-weet!
You need to locate the source and then address it.
If the shell around the steering wheel is not assembled properly, then it will rub. A close examination can tell you if the shell is crooked.
As some one said .. use your ear-***** to locate the source of the sound.
Salim
Louis808 (09-17-22)
Old 02-16-13, 05:59 PM
2KHarrier
2KHarrier's Avatar
Turns out it was the shaft where it goes through the fire wall. I sprayed silicone lubricant on the shaft and it quieted right down...
I love the easy fixes....
Old 01-09-15, 09:33 AM
dashrendar
dashrendar's Avatar
Hi all,
My wife's RX300 2002 also makes a squeaking noise when turning the wheel only on very cold days and I wanted to try this solution as I have white silicone lubricant.
Is the shell that covers the shaft and firewall easy to remove? Are there any screws or does it just snap out?
Thanks in advance.
Old 01-16-15, 08:19 PM
maorsela
maorsela's Avatar
Originally Posted by dashrendar
Hi all,
Thanks in advance.
It should be exposed, right behind the pedals. White Lithium Grease spray made is quiet as a whisper on my 2002.
Old 01-22-15, 06:10 PM
DewHawk
DewHawk's Avatar
Thanks for the tip. I spayed with WD and noise was no longer.
Louis808 (09-17-22)
Old 01-17-21, 09:55 PM
Marle
Marle's Avatar
Originally Posted by salimshah
Do you hear the noise when you are holding the steering in a turned position or it happens while you are spinning the wheel?
Noise in the first case is due to the pump and in the second case is typically a scrubbing sound [around the steering wheel or at the base where the link pass though the fire wall.].
When you say the pump is good, are you saying you are getting assist? I would also look for bubbles in the reservoir during or right after the pump use. Bubbles mean trouble.
Salim
I'm also experiencing a kind of sounds like sandpaper when I'm turning the wheel or some sort of spring in the blinkers section 05 es330
artesuave (06-12-22)
Old 01-17-21, 11:10 PM
salimshah
salimshah's Avatar
I would check the power steering fluid level and also check/post in ES forum.
Salim
Louis808 (09-17-22)
Old 06-12-22, 02:24 PM
artesuave
artesuave's Avatar
I'm getting this noise on my 05 LX470, where should I be spraying the wd40? thanks.
Old 06-13-22, 06:54 AM
salimshah
salimshah's Avatar
You really need to zero on to the source of the sound. Noise is due to rubbing so use eyes and ears to locate. You may get more help in LX470 forum [crowd sourcing will be more apt]
WD40 is not the best lubricant [and many say it is not a lubricant]. Use a silicone based grease safe for rubber.
Salim
Louis808 (09-17-22)
gs300by
01-06-16 05:24 PM
zig
10-28-12 10:45 AM
Quick VR-4
08-02-12 10:30 AM
lexus18
GS - 1st Gen (1993-1997)
08-12-11 08:39 PM
GordoNx3o9
02-15-09 07:07 AM
Quick Reply: Steering wheel making noise when turning
