VSC and Check Engine lights on, but computer says ...
Hello all, I have an '01 RX with ~113K miles. For a couple of months now, when I have the steering wheel all the way to the left, on a stopped car, and I give it gas, the VSC will kick in. Today, driving normally, VSC and CEL came on. I checked it to see what codes it was throwing, and to my amusement, the computer blame it on a bad catalytic converter. I got the lights reset and they haven't come back. What gives? -TIA
Well, the light came back again, after ~200 - 300 miles. This time I was able to note the code. It is P0420 Bank1 and says something about a bad cat. Is this an O2 sensor? I really hope it's not the cat.
-TIA
-TIA
Super Moderator
That 420 code was common in Mexico and really had more to do with the gas quality and bad air making poor combustion. Sometimes it comes and sometimes it goes.
Yikes, this is no good news. I don't have anyone with that advanced scanner to check it :-( I found a similar problem in the ES300 forum, and the solution does not seem clear:
https://www.clublexus.com/forums/es3...-bank-1-a.html
Super Moderator
Generally, if after clearing the code, disconnecting the battery several times and still this code comes up WITH a functioning O2 sensor (meaning that you can actually see numerical readings on this bank) then something is up with the cat. Might take a second tank of gas to clear things up.
99es300
17
07-17-06 08:11 PM
