help me narrowing down the brake light problem
Old 02-07-10, 07:14 PM
targis58
targis58's Avatar
Default help me narrowing down the brake light problem
my brake warning light has been on and off or sometimes constantly on for a while past couple of month. Manual says to check either brake fluid level or the parking brake if it s not fully released. The fluid is full and light goes off if I disconnect the level sensor. Does that mean the problem is from the sensor (shot possibly) ? Will disconnecting the sensor bother computer to read the parking brake failure and illuminate the warning light? If the sensor seems to be the problem, is there a way to check the sensor to make sure it is the problem?? thanks
Old 02-07-10, 08:36 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
I think you dont need any help. You have already figured it out. If you have a vom you can check it further by moving the float up and down. I am bit **** in keeping things right, so I would replace the sensor/cap.
Salim
Old 02-07-10, 10:51 PM
lexina
lexina's Avatar
Your brake pads are low.
Old 02-10-10, 07:08 PM
trhs75
trhs75's Avatar
If pads are OK, try a new fluid reservoir cap. It's about $100, but it solved my problem with the chime and light always blinking. There's some kind of chip in it; more than just the fluid level switch, and that's what caused the problem.
sam12345
03-16-15 09:39 PM
AlexusAnja
11-30-10 08:19 AM
mrchacon
06-28-09 10:39 PM
sonbum1
13
03-01-07 07:13 PM
philES300
Maintenance
10-16-06 09:21 PM
Quick Reply: help me narrowing down the brake light problem
