Who drives with their ABS disabled
I hate my ABS system and am going to disable it
I know how to drive and if I want the brakes down full and to skid then dammit it want it to do what I tell it.
anyone else drive with their ABS disabled?
on a side note has anyone upgraded their brakes? I think stock rx 300's brakes are pretty damn good but I think they could be better
Super Moderator
P.S. I plan to bleed my brakes today. I'm going to use Pentosin DOT4 fluid in place of ATE SuperBlue this time (because I like to test out stuff). I'm also close to doing another brake pad change soon (ordered some Axxis Deluxe pads as a trial). Would you believe I have about 3 years on my pads compared to when I was running through pads about every 6 to 8 months back in Mexico City?
I've used a lot of different brake pads on my RX300 (EBC, Hawk, Carbotech, Ferodo among others), but nothing quite topped out the Akebono Pro Act pads (got them on www.rockauto.com). I'm currently using, though the Axxis pads have always peaked my curiosity, so I'm trying those this time.
Ask TunedRX300 about brakes, pads and rotors, he's done quite a bit in that department.
Can't speak for dry or wet conditions but I've tried no ABS versus ABS in packed snow in our RX and Camry. Hands down, you'll stop better and be able to concentrate more on steering with the brake pedal down and the ABS working.
maybe i need better brakes then?
Im still using stock everything...
i have 50% life left on all my brakes
i just wish it could stop faster, it takes a huge nose dive and stops but not quite anywhere near as fast as the car i drove before ( volvo 850 turbo )
and when you put 5 people in it...it doesnt stop like i want at all.
Any upgrade you do, will make a difference in feel (more or less pressure to bring the disc to a stop) and brake fade. The brake fade is the reduced braking affect due to elevated temperature of the disc-pad-fluid.
Suspension upgrade will affect the weight distribution and you can get the rear brakes to better assist.
The easiest thing would be to reduce the weight you carry. Then get bigger and wider tires, and get better gripping tires (you will have to give up on number of miles you can put on them).
Salim
Super Moderator
I just finished bleeding my brakes, what a world of difference. Last time I bled them was back in 2007, about 20K ago.
The ABS will work better under snowy/wintery conditions. I've tried it in rain/wet conditions and I can't see any difference with/without, but in dry conditions, I stop better without it. Even on the track, I found out it was better without it and I was able to to do much smoother braking in bracket runs (where stopping is used).
I can't speak for the rest of you as far as ABS, but I know my personal experience on it. If I were up further north in the land of snow, I'd consider otherwise.
You must have a good idea of how much pressure to apply on the brake pedal and back off just before the wheels jam-up. The ABS actually wait till the wheels jam and also waits till the wheels start turning. So one can out perform them.
ABS really shines on slick surfaces as a typical driver in skid (wheels jammed) situation tend to press the brakes harder, while the right thing is to let the wheels roll to get traction.
A colleague of mine , who was an expert driver also lamented about ABS and his claim was that he would let the tail swing forward and cut down the stopping distance ... but I guess he needed the right lane empty.
Salim
Salim
Super Moderator
Salim
Salim
On the track, I needed to the brake when I wanted it to do an no more, so if I realized (in bracket racing) that I overshot a competitor and had to slow down to not break out of my time bracket, the last thing I needed coming out of 60 to 70 mph is for the ABS to suddenly kick in. I just needed a light dab on the brake, but before when I had the ABS engaged, it would, for lack of a better word, overbrake, or brake a bit longer than I wanted and screw me up.
There were wet conditions on highways and streets out there, but I never seemed to be unable to handle any extreme braking condition.
