occasional hesitation from a stop
Old 02-13-10, 10:46 AM
phil128605
phil128605's Avatar
Default occasional hesitation from a stop
Hey guys, I recently got some problems straightened out on my 99 Rx with the help of some members here and really appreciate it. Now, my RX is occasionally hesitating from a stop. It does it maybe 2 or 3 times every time I drive it. It seems like, if you really ease into the throttle, it will have a hiccup, then accelerate, but if you just gas it and go, it will never do it. Im wondering if it could be the IACV but I searched and it doesnt have any of those symptoms. It idles fine, accelerates great now due to new plugs, and has no other issues except this occasionally hiccup. Any input is appreciated.
Old 02-13-10, 03:54 PM
Lexmex
Super Moderator
Lexmex's Avatar
I am not sure what you mean by easing into the throttle.
The IACV is one such source of misery there, but another one can be the ABS that can when you come to a stop and are under 5 mph, cause an occasional hiccup.
Do you see any kind of spike in RPM when this happens?
Old 02-13-10, 05:23 PM
phil128605
phil128605's Avatar
No spike in rpm, it just stumbles and wont go. By easing into the throttle, I mean by slowly pressing the pedal down.. But, if I just give it more gas from the start, it wont happen. It only does it from a dead stop.
Old 02-13-10, 10:08 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Two things come to mind ..
TPS ...throttle position sensor
Lexmex mod ... adjust slack on the throttle wire.
Salim
Old 02-14-10, 08:00 AM
hypervish
hypervish's Avatar
I want to do the throttle wire mod but don't really understand which bolt to move and which way. Can anybody post a picture after the mod is complete? I just want to see what to move so I don't screw anything up.
Old 02-14-10, 08:41 AM
Lexmex
Super Moderator
Lexmex's Avatar
https://www.clublexus.com/forums/rx-...se-advise.html see post 5,there's two bolts there and you want to move them as far as left as possible. Start with the bolt furthest to the left.
Old 02-14-10, 08:44 AM
Lexmex
Super Moderator
Lexmex's Avatar
I'd check to see if you have any exhaust leaks. One area that is prone to them and can cause such a hesitation is here.
Old 02-14-10, 08:50 AM
hypervish
hypervish's Avatar
Thanks Lexmex, I've seen that thread before as well but do you have another picture after the screw is moved. I'm not sure how much to move it.
Old 02-14-10, 09:19 AM
Lexmex
Super Moderator
Lexmex's Avatar
As far to the left as possible. There's a point it can't go anymore and will come to a stop. I believe the photo above does show it in it's final position as far left as possible.
Old 02-14-10, 09:23 AM
hypervish
hypervish's Avatar
Okay, thanks I will try this later today when I try and locate where the oil is leaking from.
Old 02-14-10, 09:54 AM
phil128605
phil128605's Avatar
check engine light came on today- Codes P1349 and P0300. That is the VVT oil valve on the hard side I believe. I just had this same issue on bank 2 a few months ago, and I removed the OCV and cleaned it with deep creep, and havnt had a problem with it since then. I guess I will try it with this one as well. Is this the correct aproach? By the way, there was no sludge in this engine when I changed the valve cover gaskets this week, and it has 180k. Hard to believe right.
Old 02-14-10, 10:06 AM
Nad1370
Nad1370's Avatar
I would'nt say it's the hard side .
Still held by 1 10mm bolt.
Just have to move some vacuum hoses out to get access to it.
My brother had this problem. Same bank.
When I took it out. I shook it and it sounded like there was something loose inside. So I think trying to clean it would'nt work.
He decided to replace it.
If cleaning worked for you on the other side, then by all means try it.
I you do regular oil changes...It's easy to believe you won't have a sludge motor.
Old 02-14-10, 10:14 AM
salimshah
salimshah's Avatar
I myself take lot of advice from Lexmex, but I have slight difference in opinion on how much/little slack on the cable. You should follow what works for you.
The cable loops around the wheel like thing that is the throttle-shaft. You can hold the wheel and spin it [just like if the cable would spin it]. Do this spin action and you can tell how much slack is in the cable. I would say the slack should be at least 1/8" inch.
Salim
oneforu2c
05-16-22 10:18 AM
jimskelton
17
11-03-12 03:46 PM
palm67
12-21-08 09:10 AM
GlobeCLK
10-28-06 08:46 PM
Quick Reply: occasional hesitation from a stop
