2001 rx300 front bumper cover
I was trying to replace the front bumper cover today but I got stuck... ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
which components do I need to remove to change just the bumper cover???
JPBLEX (01-19-20)
The hidden screws, which you accesses through the wheel well. They are shown in the illustration on extreme edge of the bumper.
Salim
Salim
Besides the screws mentioned, there is a plastic clip just forward of the hidden screw with one of those one-way fingers that engages the second mounting ear on the top rear of the bumper cover. You might be able to slide a shim or long thin screwdriver to push it up but I wound up breaking it (accidentally) so had to temporarily install the bumper with this damaged clip. It is difficult to remove the clip without damaging the fingers that hold it on to the fender metal. I will be making a trip to the dealer to see if I can find it. I believe it is referred to as 'bumper cover, clip, side'.
EDIT: part number is 90959-01577 - described as CLAMP on Lexus invoice. $13.43 OTD :-(
BTW, $5 as a Toyota part HERE:
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Hey jagalchi88, I know this is quite an old thread, but can you share how your front bumper cover replacement went? Any additional tips you can share beyond the screws and such mentioned so far? I am about to do the same, and would appreciate any advice.
There is nothing 'one time use' part. If the clip is damaged/deformed then replace it.
Salim
Salim
Understood, but the reason I was asking the OP is to get a better sense of whether that clip broke (as another post suggested it has the propensity to do) during this repair procedure. That way I know whether to buy a new clip and have it ready and available before I start.
Salim
alwayzspeedin
02-15-10 12:04 AM
awol707
01-17-08 08:23 AM
