Any DIY headlight removal?
Hello,
I'm trying to change my headlight bulb on the passenger side and it's difficult because there's not much room to remove it. I assume I have to take out the front bumper and remove the headlight in order to do so? Any pics would be much helpful.
Thanks,
Thanks,
You don't remove anything... It's a tight space, but it's doable. I've replaced them 2-3 times with my RX and I've got pretty big hands, but any girl oughtta be able to do it for you if your hands just can't pull it off. I asked my wife to do the sidemarkers for me after an hour of fiddling with it... took her 30 seconds
I have HID's so I'm not sure if it's more difficult for the passengerside. I couldn't even take off the round rubber cover. I see the bulb and the two prongs hooked on. In front of it is this square box with steel tubes bent all over the place (What is that?) Anyone with a picture of how the headlight assembly looks?
I don't remember if it helps or not, but you can remove the bolt that holds the windshield washer fluid fill tube in place. Once you remove the bolt, the tube just twists out. That should give more room to get to things.
jkayca
ES - 5th Gen (2007-2012)
04-13-15 12:20 PM
