2001 RX 300 0171 and 0174 codes showing
Old 04-12-10, 07:16 PM
Sc5Speed
Sc5Speed's Avatar
Thanks for asking Lexmex, I went by a shop and explained my problem, I left the car with him and an hour later he called and said he was looking over the car he hears a vacumn leak, pulled out a stesascope and says i need a intake manifold gasket, he also proceeds to tell me someone cut a bracket to the motor in this area? Have you ever heard of someone doing this and will it be a problem in the future?
Old 04-12-10, 07:49 PM
Nad1370
Nad1370's Avatar
Originally Posted by Sc5Speed
Hey Everyboby
Thank you for the help, Now get this....I changed the Bank 1 upper sensor and the little rectangle A/F curcuit , So after changing it and clearing it the Check Engine light the Trac Off and SCV lights come back on .So that was Friday evening and they were still on saturday, then sunday they went off, I was excited hoping the problem has been addressed, But nooooooo All 3 came on again this eveing after driving around alot today with them off....check engine, Trac off and SVC lights...any thoughts? is this some kind of short or???
Why did you think replacing 1 a/f sensor would fix the lean codes on both banks?
As I said in an earlier post:
Check for vaccum leaks in the intake side: hoses, plenum gasket, etc...
This would have saved you $ rather than buying an A/F that you don't need.
There are 3 gaskets for the intake.
1 is a plenum gasket (metal) between the intake manifold and the plenum itself.
2 intake manifold gaskets. in between the intake mani and the cylinder heads.
Which one(s) have the leak?
There are 2 brackets behind the intake plenum supporting it. Which one is he talking about?
Old 04-13-10, 07:31 PM
Sc5Speed
Sc5Speed's Avatar
Damn if you didnt nail that on the head, I think the one on the left, Could that be a problem in the future?
He said I had 2 places where I was sucking air, the intake manifold had a leak and the gasket it looks like who ever put it in before I have owned it dropped it in sand first since it has sand looking particals sticking to it everywhere. He said I was also missing O-rings on 3 fuel injectors , He charged me $171 today...... How long do you think it really took him?
The reason I changed only one A/F sensor is when I did that to my Sc it worked when I had some problem? I did not need both and I thought one of the first steps was to change the sensor. Wasted money I guess.
Old 04-13-10, 08:42 PM
Nad1370
Nad1370's Avatar
Well, the plenum is held down with 2 bolts and 2 nuts. Supported by 2 brackets in the back. I think the one bracket on the left has a hook at the end of it.(I think to hook a chain there for lifting the engine out)
I probably won't be worried about it too much unless a 500lb. raccoon decided to nest there
Well if you were missing injector O-rings, there would be a fuel leak present.
If he did all 3 gaskets, that's an awesome price + o-rings. But if he just did the plenum one I guess that's not too bad of a charge either.
Probably the same amount you spent on that A/F huh?
Can't say how long the job would take cause I haven't done one.
I'm thinking a couple of hours for the plenum gskt and o-rings.
Onitlex96
08-29-11 03:49 PM
bsmrx300
01-29-11 12:45 AM
00RX300
28
02-25-09 09:48 AM
Yaman
11-14-08 08:36 PM
Quick Reply: 2001 RX 300 0171 and 0174 codes showing
