Transmission Issue
Transmission Issue
I am new here and we have only had our 2002 RX300 since September but it has 154,000 miles on it. We've never had any problems at all with it until now. We drove it earlier today with no problems at all, but I just got in it to run to the store and it was fine at first but I got about 3 minutes down the road and it was shifting really low like at 1000 rpms. So I pulled into a neighborhood and turned it off and then turned it back on and all the sudden it wouldn't let me put it into drive, like I could put the gear shift into drive but it wouldn't light up on the dash or even go anywhere. So I put it into 2nd and nothing and then low and nothing. So I turned it off again and then back on and it would drive into 2nd and low but revved really really high then all the sudden nothing. So I pulled over again and turned it back off, called someone to come get me but then tried again and it went into 2nd and I was able to drive home. I had a hard time pulling into our driveway even though it's not steep at all. Does this sound like the dreaded tranmission failure? I read that someone else had similiar problems and did a fluid change and changed the filter so I'm going to have my husband do that this weekend in hopes that it will work. What do yal think it sounds like to you though? Also, could someone tell me what we need to do to do the fluids and filter change.
good luck and i hope not , sounds like a clogged tranny filter blocking the fluid and reducing pressure causing it to strain alot cheaper than a new tranny hope thats it let us know the outcome
Start by checking the transmission fluid level and condition.
At this time I would suggest postpone other fluid change [just make sure the levels are good]. Once the transmission issue is resolved then get into replacement of other fluids.
Salim
Salim
Hopefully a fluid change is all it needs but I fear the worst has happened.
Check fluid levels first or leaks present.
Here a DIY sticky thread that will help you change the Trans fluid:
https://www.clublexus.com/forums/rx-...er-change.html
Yikes..!!
OOO no don't say that! This is the last thing we need, we are about to be moving to Hawaii in about a month so this is not good.
Yea, Hawaii. He's in the military, he's a helicopter pilot.
HAHA ok thanks. Well I just talked to my dad who has been working with cars since he was 13 and he says it sounds like it's not getting transmission fluid. AHH I hope that's what it is, we just had the clutch go out on my husbands jeep the day after we bought it but it was under warranty so it was covered, but this wont be.
Condition of the fluid is the first thing to check. If there are no suspended debris, it is unlikely the filter is clogged. Did we talk about the level?
There are couple of solenoids that can be swapped ... search the net.
If you have the wire-mesh filter and you suspect particles in the fluid, I would wash and reuse the filter and drain and fill a few times. Then drop pan and replace the filter. Also i would re-use the gasket [so what if it leaks a bit], if you plan to drop the pan again in few days. Only on the last drop, I would use the new pan-gasket.
Just think ahead and save some money on parts. The cost can add up to 3 figures .... still lot less than 4 figures for replacement or transmission.
Salim
Salim
