PCV oil into intake
PCV oil into intake
I ran across a guy that put a air dryer (like on an air compressor) between the intake and the PCV valve. He gets about two table spoons between oil changes. He did this because he didn't like the amount of residue inside the intake. I might give it a shot on the Lexus.
Take a peek:
http://www.pbase.com/rsrock/oil_catch_can
Take a peek:
The oil catch can...it's a common practice. There's a whole bunch of members at Solaraguy who do this on their 1MZFE powered Solaras.
What I have right now (and some of you are going to scoff, but hear me out) is the PCV valve is hollow and just vents to the air (no hose or return line to the intake manifold). Same thing goes for the hose that links from the top of the front engine bank to the air intake tube, just a hose to air. Now, one might think that the oil will drip everywhere and create a mess, but for well over 1.5 years since I started this system...not an issue. Result is that oil residue is not shoved back into the engine combustion cycle thus providing a cleaner burn out the back end...better MPG and power. I guarantee you that my HC (hydrocarbon count) is a lot lower as result.
This won't throw a code, but you have to cap off the places where the hose connections are on the manifold (see where those rubber stoppers are), see http://www.cardomain.com/ride/2215309/6 (see at the bottom). I deleted those little air filters in the picture and the PCV valve is hollowed out.
The only thing I worry about that is the pcv makes a small amount of vacume in the engine, that helps keep the oil leaks to a min. If he has done it that long I think it prob ok.
If the hoses off the pcv run up hill it helps prevent drips. On my truck (18 wheeler)it is a 1/2" hose that runs down to the ground. I think it just keeps the engine from pressurizing and blowing out seals
Perhaps I can show some more photos later of the setup to get an idea.
The thing I have been playing around with for sometime is bored out PCV (plastic since it is a 1999) with no hose attached (that's the passenger side) and just leaving the hose on the driver's side off of the connection to the air intake (and I capped off the air intake with a rubber piece). I haven't had an issue with this at all for...well since god knows when, it's definitely been since a few months after my previous post above. Have not seen any issue with my oil consumption either (no crap in the oil when I drain it). That hose that hangs down off the top of the crankcase shoots out some vapor but have not had any real oil residue or anything accumulating on top of the tranny.
Generally, this shouldn't be done as to get that crud/vapor out of the engine, you need the engine process to suck out the stuff via the attached hoses. Vehicle does run much smoother, no power or mpg loss.
If not, then a plastic push in like this:
How do you replace it?
It's not plastic so I guess you have to unscrew it with the wrench or something? sorry kind of dump question but I just don't want to mess it up!
I called the dealer and gave them my vin# they said it metal not plastic.
What is the best way to replace it? Thanks.
See post 11.
In either case twist the hose (going to the intake side) to break the seal and pull it off.
The picture on the top (pcv by itself) has threads and you use a wrench to undo it.Depending on the model (your vin number), lexus switched to a different valve cover and a different pcv.
The lower picture shows insitu pcv and it is plastic. Follow the white arrow. You remove this one with a twist and pull action.The rubber grommet should be replaced if it has become hard. You have to be careful as the rubber grommet breaks and tends to fall inside, but there is a ledge and most of the times the grommet can be pulled out.
Salim
Salim
