rear wiper groan
Old 04-24-10, 11:31 AM
cplyons
cplyons's Avatar
Default rear wiper groan
Things are going great with my new (to me) 00 RX300.
Now I am working on the rear wiper. It works barely, slows and stops mid sweep. If I "help it along" it will complete cycles. I resign myself to replacing the motor, but thought I would remove the arm first just to see what. I now have the arm off and when I actuate the wiper, it seems to have a lot of power but groans/squeaks with each cycle.
Any reason not to just grease the heck out of it and see how things sort themselves out? How do I access the motor?
Old 04-24-10, 02:28 PM
bob2200
bob2200's Avatar
The panels on the inside of the rear hatch pop off. Be prepared to replace a few of the plastic pop-off fasteners if you don't have the right touch.
I don't recall reading about this problem before, so I don't think it is common.
I would try lubing. Grease where appropriate, and oil where appropriate. Maybe you'll spot some obvious problem when the mechanism is exposed.
Old 04-28-10, 08:48 AM
lexus114
lexus114's Avatar
sounds like the motor is shot. Although one would not think that is the case,how often does the rear wiper get used? Maybe the previous owner/owner`s used to leave it on (weather it was raining enough) to have it on or not. I see that all the time around here. And with out enough water on the glass,it create`s a drag for the motor.
Old 04-27-13, 05:18 PM
2KHarrier
2KHarrier's Avatar
Hate to resurrect an old thread, but I pulled rear wiper motor out today and lubricated the shaft that drives the wiper arm. Had some corrosion on it and was as dry as a bone. I cleaned the corrosion off with some emery cloth and after getting it all lubricated and put back together, it works smoothly and very quietly.
Took a little over an hour...
Old 03-22-20, 09:39 AM
drgerry
drgerry's Avatar
Has anyone ever tried to replace the mess fabric with silver reflective material? Seems that would do a better job of keeping out the direct sun and limiting the heat and decomposing of the interior.
ericsan13
RX - 3rd Gen (2010-2015)
15
05-19-14 08:44 PM
ak11
04-12-13 09:42 PM
blackdog69
11-14-11 02:01 PM
BlairC
GX - 1st Gen (2003-2009)
01-23-11 09:38 AM
Quick Reply: rear wiper groan
