Motor Oil Filter Question
Lexmex: I just went on Amazon and found the HP-2009 and clicked on their little "does this fit your car" link and it came back negative, saying that this filter wouldn't fit a 99 RX. How much stock to you put in these? If you have used them then I am going to order one anyway...
JBL
JBL
Lex
JBL
JBL
I just use OEM, but if I were upgrading and wanted something larger, I'd go with Lex's experience.
JBL
JBL
The HP-1002 is the size of the OEM filter, but the HP-2009's only difference is that it's a bit longer, it still fits.
The oil change photos above show the HP-1002 and also the HP-2009 so you can see the difference, but they both fit our engines.
The wix filter look up is helpful. The long filter in wix is 51516. 51648 is stock. All the internals are the same. Its just longer.
Stock:
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-10), Various GM, Saturn (85-07), Lexus (90-10), Saab (67-09), Suzuki (86-02), Toyota (88-10), Ford (03-10), Mazda, Mercury (05-10), Yugo (86-89), Various Lawn&Garden, Farm Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Long filter:
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Lincoln/Mercury (81-09), Chrysler/Jeep/Mitsubishi (02-09), Mazda Trucks (94-10), Various Industrial Equipment
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Beta Ratio: 2/20=14/31
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Stock:
Part Number: 51348
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Thread Size: 3/4-16
Long filter:
Part Number: 51516
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Why not use OEM filter with M1 syn oil, and change it once a year between 6-8k miles.
All,
With yearly mileages of both RX's between 6k and 7k, I am thinking of doing a drain and fill only midway through these times or mileages. In other words, I would do a drain and fill at 6 months (roughly 3-3.5k miles) and full filter change at 12 months (6-7k miles) for each of these cars. I just wonder with as little mileage I am putting on these each does it make sense to change the oil filter that often...can I get away with just doing a drain and fill at 6 months?
Not gonna hold anyone to the fire on this but I am curious to what you all think?
Thanks,
JBL
Thanks,
JBL
VHTx2011
17
09-10-11 04:09 PM
shyishguy
08-22-07 07:12 PM
