Slip indicator on right turns, 2002 RX300
Hey all. 2002 RX300, I've been having an issue recently with the slip indicator light (not ABS, VSC, etc..., but the car with the two little squiggly lines under it) with a beeping sound when I've been going at higher speeds and then do a gradual turn (like you would find on freeways). It will beep at me for a little bit (maybe 10-15 seconds) and then will stop when I am going straight.
What could this be? The steering seems to be fine, certainly dry out so I don't think that it is actually slipping, the tires are fine and inflated.
Gomer1
RX - 1st Gen (1999-2003)
13
10-28-10 08:42 AM
