P1150?
P1150?
Lit up a P1150 today which looks like the front air fuel sensor. Which is a pisser since it was just replaced under warranty 10k miles ago (warranty is expired now). Assuming I should just clear the code and see if it pop right back up. If it does just replace with an OE sensor and call it good? There is no way to try to "clean" the sensors right?
Thanks!
Thanks!
Hi Carguy: My 01' RX300 gives me occasional " P1150" check engine light. I reset it and its good for weeks, then pops on again. I thought it was a gas cap problem. Where is this sensor ypou talk about. ?? edvanb@hargray.com
It's the air fuel sensor that is in the exhaust manifold up front by the radiator. Have you tried any fuel system cleaner yet? Mine has not come back yet and I did not do anything other than reset the light.
https://www.clublexus.com/forums/rx-...-sensor-3.html
