P0120 Code - 99 RX
Old 06-21-10, 07:11 AM
jbl-1985
jbl-1985's Avatar
Default P0120 Code - 99 RX
Folks,
For the longest time (years!) this 300 showed no codes...now all of the sudden, it is showing a throttle position sensor code.
I can't help to think that I might have done something dumb when I recently put a full charge on a battery, then connected the terminals immediately after the charge, and when I did the negative terminal sparked a bit, which I thought was normal, and then 5 minutes into the drive the CEL came on and viola...the P0120.
Anyone ever replaced one of these sensors, and did I unecessarily jolt the electrical system by hooking up the battery too soon after a full charge??
Many thanks for any replies.
JBL
Old 06-21-10, 01:38 PM
Lexmex
Super Moderator
Lexmex's Avatar
The TPS can be susceptible to jolts.
With some electrical testing equipment one could check the voltage in this sensor (area noted below).
The times I have seen this come up with other vehicles it has been replaced, but checking the voltage would reveal the issue, let me know.
Attached Thumbnails P0120 Code - 99 RX-img_2723a.jpg   P0120 Code - 99 RX-img_2730a.jpg
Old 06-21-10, 03:48 PM
jbl-1985
jbl-1985's Avatar
Lex - Thanks much for the info. Saw the actual part is only about $50...looks like a pretty simple install however if we have to take the throttle body off that may be more cumbersome.
Interesting that this and other sensors might be sensitive to a jolt...I just hope I didn't mess anything else up that might be a whole lot more expensive...
Luckily I have a seasoned Toyota mechanic for a neighbor!
JBL
Old 06-27-10, 09:25 AM
jbl-1985
jbl-1985's Avatar
Well the sensor has been replaced and maybe I am reading into this a little too much but the car really shifts a lot smoother as a result of this particular repair...It would seem that the sensor was slowly failing and now with a new unit in place, the car really just runs that much better...just wanted to finish the thread with another success story.
JBL
Old 09-30-15, 07:44 AM
freaklexus
freaklexus's Avatar
thanks for the help
mackieman
21
09-17-22 11:38 AM
NoUltimatu
05-14-15 05:09 PM
Ravencrave
11-25-13 08:11 AM
aekhhi
06-27-11 06:55 PM
Benjamin T
Performance
01-22-07 08:22 AM
Quick Reply: P0120 Code - 99 RX
