Running wires from top of dash down to the floor
I have an 03 RX300, and wold like to install my sattelite radio properly. I;d like to leave the antenna on top of the dash, tucked into the front passenger side corner (i.e. between the speaker and the glass). Can someone suggest how I can fish the lead wore from the top of the dash down to the center console (between driver and passenger seat) where the radio is located?
I did my XM satellite radio installation back about 8-26-10 and wrote it up, with photos, here on this forum. I mounted the satellite radio antenna in the middle of the roof and placed the XM receiver over where the optional seat heater controls would go.
You just open the glove box to access the 10mm(?) bolts that holds that portion of the dash panel. That gives you access on the right side of the dash. There are other good write-ups on removing the center console, if that is needed. There are a number of clips that need to be gently removed.
