RX300 2001 knocking noise in the rear!!
Hello all I was hoping that I could get some help with my lexus that has
a good 130,000 miles but it runs great except for a knocking sound that
comes from the rear of the car.. It usually happens when you step on the
accelerator when the rumbling sound begins... I spoke to someone about it and
he mentioned the rear shock mounts might be the cause.. Any help will be appreciated...
Super Moderator
Yeah I had the same issue with mine. at around 130,000 miles or so I started hearing a knocking/squeaking from the rear end over bumps specially when it was cold outside. Let Lexus service take a look, the rear shock was leaking fluid. They replaced it about $500 installed.
