do I need to remove window regulator in order to take out door lock actuator?
My original door lock actuator/assmebly died to day. It's the original
one that came with my '01 RX300. (the driver-side front door)
I plan to buy the OEM actuator... yes, I know it's $$$...
Is it possible to take out the actuator without first removing
the window glass regularor mechanism in the RX300?
Thanks!
Thanks!
SC experience is that window rolled up. Undo the panel. Remove moisture barrier. Unbolt (torx screws) the door-catch. To create room to bring out the lock, I had to un-screw the bottom screw of the glass guide. [Sc is a coupe, RX rear door has a cut].
Most important is keep track of how the thing comes out. Mimik the same twist and turns when you put it back. Lucky for you, there will be no key lock mechanism.
Salim
Salim
