Side Marker Light Buldb Replacement
Old 08-28-10, 06:48 PM
jgaynor
jgaynor's Avatar
Default Side Marker Light Buldb Replacement
My 2000 RX300 has several side marker (corner) bulbs burned out. Can anyone tell me if the lenses just pop off or do I have to dismantle the cargo bay interior again? Also have the smae question for the bulbs in front.
Thanks
Jim
*Drive gear indicator light
*Drivers door actuator
*replace radio antenna and rebuild motor
Old 08-28-10, 08:42 PM
carguy07
carguy07's Avatar
http://home.comcast.net/~rx300how2/side_markers.htm
Old 08-29-10, 05:54 AM
bob2200
bob2200's Avatar
Note that some RX's have poor seals and water can fill the lamp assembly and corrode the contacts. If this happens, there is a short part that fits between the wiring harness and the bulb that can be replaced. Also, I followed the lead of other forum members and drilled a small hole in the base of the leakey assembly to prevent future flooding. This only happened at age 5 years on one of my side marker lamps.
Old 08-30-10, 04:33 PM
sktn77a
sktn77a's Avatar
I've replaced all of the sidemarkers on my '99. In all cases, the socket was corroded and had to be replaced.
Old 08-30-10, 11:10 PM
jgaynor
jgaynor's Avatar
Default Side marker Lights
Thanks guys! Just what I was looking for.
Regards,
Jim
Old 06-09-16, 03:40 PM
GarageGuy9
GarageGuy9's Avatar
I need to change my right front marker light on my 2000 RX300. The above link does not work can anyone supply a replacement. I don't see access thru the wheelwell or under the hood. Does the lens pop off? Thanks in advance.
Old 06-09-16, 04:23 PM
GarageGuy9
GarageGuy9's Avatar
Disregard. Found enough info on another thread to figure it out. Link here still doesn't work for me. Maybe some one can correct it for the next guy.
Old 06-09-16, 04:42 PM
Lexmus
Lexmus's Avatar
Here is a photo of the back of a front side marker. You can see how it engages with the bumper panel. You access the nut holding it onto the bumper and the connector via the wheel well. More info here:
https://www.clublexus.com/forums/rx-...ker-light.html
Attached Thumbnails Side Marker Light Buldb Replacement-side-marker-back1.jpg
Old 06-09-16, 10:16 PM
GarageGuy9
GarageGuy9's Avatar
That was fast. Thank you very much.
Old 12-17-16, 03:28 PM
maorsela
maorsela's Avatar
Hi guys,
tried to finally replace my side marker bulbs after years, but the burnt out bulb is so corroded, and the socket as well.
Is there anything I can do to clean it up? or does the socket needs to be replaced? If yes, can anyone provide part numbers? Front markers, rear markers.
Thanks!
Old 12-17-16, 06:25 PM
aznlapin
aznlapin's Avatar
I would personally cut off the socket and solder on a new one with heat shrink to protect the wires. I replaced mine this past summer and the corrosion went pretty far up the wires. The bulb is 194, I went with LEDs.
Note, the setup is: wire - wire harness socket - bulb socket - bulb - lens assembly
The easier route would be to clean the socket by dipping it in a salt+vinegar solution, then neutralizing the acid bath with a baking soda solution. Good guide on copper cleaning right here.
Old 12-18-16, 07:06 AM
bob2200
bob2200's Avatar
I had a side marker fill with water and corrode the socket many years ago. At first I thought I'd have to splice into the wiring harness but discovered that the socket and a relatively short lead with connector attached are available as a spare part. As was written about here maybe a dozen years ago, drilling a small hole in the new side marker bottom allows any water to drain out, so the problem can't happen again.
Old 10-01-17, 01:16 PM
PGriff
PGriff's Avatar
Dead link.
Old 10-01-17, 05:24 PM
sktn77a
sktn77a's Avatar
Originally Posted by PGriff
Dead link.
Not unexpected from a 7 year old post.
Old 10-01-17, 05:43 PM
Lexmus
Lexmus's Avatar
The link in my earlier post in this thread has a link to a pdf file with the instructions and photos.
https://www.clublexus.com/forums/rx-...ml#post7035497
tejanp
01-30-18 05:09 PM
JoeRX300
05-01-15 09:47 AM
Humaira
11-05-13 09:22 AM
mansuper
11-11-07 06:14 PM
Bercasio
02-15-06 11:53 PM
Quick Reply: Side Marker Light Buldb Replacement
