2003 RX300: My first check engine light appeared (VSC & TRAC OFF)
Car has been running great (except for a bad lock actuator).
I recently went away and parked the car at the airport for 10 days. When I got back, the check engine light along with VSC and TRAC OFF immediatley went on.
Any ideas? I haven't changed the air filter in apprx a year, but regular maintenance including the 60K service was done about 18 months ago.
Perhaps this is a clue- there were very heavy rains in the DFW area while the car was parked outside.
David
David
UPDATE:
I just came back from AutoZeone and they read code
P0442- EVAP
The manager suggested it is either a bad gas cap, or leakage onto the charcoal from overflowing the tank. My gas cap looks just fine.
The only change from before and after the code is that I left the car parked for 10 days , which included a heavy rain storm.
I just removed the EFI fuse, and will see if that resets it.
Anyone have specific experience with P0442?
P0442- EVAP
Strange, the same thing just happened to my ls430. I had it parked on a hill in front of my house fro 2 weeks while I was away on a trip, get back and start it up and immediately get these error codes.
I was going to try and do a reset using a paper clip and the obdii connector I saw and see if this helps.
Any luck?
Any luck?
yeah, so it happened to both of us: The TRAC OFF and VSC lights appeared after the car was parked idle for > 1 week.
I'm wondering if the heavy rians may have dampened the charcoal cannister. That can cause P0442.
thesmeazy
07-12-23 02:51 AM
