What size bolts to pull the brake rotors?
Old 09-21-10, 11:00 AM
salimshah
salimshah's Avatar
Received 1,082 Likes on 974 Posts
Originally Posted by Audacity
Where exactly is the "star" that I need to back off to release the e-brake? Do I need to tighten that back up after replacing the rotor or will it do it automatically by using the e-brake a couple times when I'm done with the job?
Star is the cogs on the end of the self adjusting nut. The drum brakes kind of float and self center in the drum. So when you assemble the shoes need to be pulled in so that the drum can go over. I am guessing that there are 60 or so spikes on the cog/star. If you rely on self adjusting it will eventually self adjust but each operation will move the cog by one. So a good mechanic will try to center the brakes and rise the shoes so that the drum can go over and the brakes do not touch the drum.
Salim
Old 09-21-10, 11:57 AM
Barryst
Barryst's Avatar
Salim is correct!
I moved mine in pretty close. (Using a screwdriver through the hole.)I had both rear tires off so I could spin it a little to feel the drag.
Old 09-21-10, 05:46 PM
trhs75
trhs75's Avatar
When I replaced my rear rotors, I was surprised to see that one of the ones on the vehicle did not have the adjusting hole. I think someone put on a cheap rotor somewhere along the way. The Lexus rear rotors I installed both had the hole.
Old 09-22-10, 07:24 AM
salimshah
salimshah's Avatar
One of the things that goes bad with the drum, is when the shoes cut a groove and end up riding higher in the drum. If there is no way to turn the star nut down, the drum will not come off.
Salim
Old 09-29-10, 06:17 PM
Nad1370
Nad1370's Avatar
8 x 1.25 is the bolt you need as everyone here said.
But here's a link on how to avoid headaches taking off the rear drum.
Refer to post #8
And yes...they are set-up like your ES300
https://www.clublexus.com/forums/rx-...ml#post5450688
Old 09-30-10, 04:02 AM
Barryst
Barryst's Avatar
For some reason, I thought my star adjuster was at the top!
-I must be loosing my mind.....
Old 09-08-12, 12:29 PM
TPenguin
TPenguin's Avatar
Refer to post #8
I'm assuming 8mm x 1.25 thread pitch is the same for an RX330, can't see why this would have changed between models but can anyone confirm that? I just did brake pads this morning on my wife's RX330 because I had rotated tires recently and saw the pads were worn almost down to the squeaker.
After replacing the pads my wife tells me she has noticed the steering wheel vibrating when medium to hard breaking at 45mph+. So I'm going to replace the front rotors soon but while changing brake pads I saw the two bolt holes on the front rotor but didn't have a correct sized bolt handy to verify what size/thread pitch would work to separate the rotor from the hub. I will pick up a 8mm x 1.25 thread pitch bolt and give it a shot in two weekends when the rotors arrive but if someone definitively knows for the RX330 and could confirm it would be appreciated. Thanks.
Old 09-08-12, 04:49 PM
carguy07
carguy07's Avatar
I know for sure that they are the same on the rear of the 330, safe bet that the fronts are too.
Old 09-08-12, 06:50 PM
TPenguin
TPenguin's Avatar
Thanks I went to ace and picked up a couple bolts. I will chime in with my results after doing the rotors, should be good.
Old 01-31-13, 09:32 PM
TPenguin
TPenguin's Avatar
Bolts worked on removing the rotors, pulling the rear rotors tomorrow to replace them.
Old 02-01-13, 05:17 AM
Baetke
Baetke's Avatar
Here's a link to a YouTube video showing how to do a complete rear brake job on a 1999 RX.
Baetke
sjrwessung
04-30-17 04:29 AM
NYG
Suspension and Brakes
20
02-26-14 01:21 PM
trhs75
09-21-09 08:46 AM
shikbas
12-22-08 05:25 PM
rerose
05-02-06 07:00 PM
Quick Reply: What size bolts to pull the brake rotors?
