Where is the GPS Reciever Located in RX300?
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Can anyone tell me where does the GPS receiver of the RX300 is?
I have a RX300 2002 with original NAV system here. The GPS signal is kinda low and sometimes doesnt receive at all.
I'm wondering where it is..so I can find out if someone took it away![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Best!
Best!
I know the GPS DVD drive, and quite possibly the antenna is located in the trunk under all of the plastic panels. All of the plastic panels just pull of; you need to pull the one's to the right side of the spare tire.
my antenna is under the front dash behind the actual reciever...however mine was a retro fit kit so im not sure if this is the actual stock location. On the plus side removing the stereo is quite simple if you want to just open it up and check. That antena might have gone bad and you could swap it out.
sleepybobcat
11-02-05 03:53 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
11-26-04 10:47 PM
