How a "tired" Air/Fuel Sensor looks
In a few weeks I'll be taking another one of my road trips to Michigan (for those that don't know, i go to Michigan every 1-2 months) but this time I will be visiting Chicago too. And so I wanted to get the sensor fixed before i headed out there to avoid being stranded and/or to avoid getting 9mpg...lol
Okay, let's just get to the point of this thread. So a month or two back I got the P1150 Code for the Front Air/Fuel Sensor (Denso 234-9009). And I ordered the part for $106 (total including tax). I kept putting off the install.
Well today I installed it, and it was extremely easy. I thought it was going to be siezed on but it wasn't bad at all, I took an oxygen sensor tool to it and a 1ft breaker bar and pulled on that ***** and it came off; I almost fell to the ground
I didn't expect it to be that easy...lol
I wanted to make this thread to show what a bad Air/Fuel Sensor looks like because mine is pretty much dead, it is 10 years old and has 150,000 miles on it.
Thanks for posting the photo. I think I'll be facing that one of these days. I've heard of oxygen sensor tools -- is it like a spark plug socket, or is it more specialized?
It is specialized. if You have a Harbor Freight near you, you can get a nice one for about $5. If you aren't going to reuse the old sensors you can just use a regular box end wrench. If the box won't go over the plug, cut it off, then you can use the box. They don't have to be tightened like a gorilla installed 'em, you can just be careful and use an open end wrench to install if the box won't go over the plug. The special sensor socket has a slot in the side so that the wire can slip in there.
I understood. Just saying that you've got your money's worth. When you think the temps the A/F sensors run and the cycles they had to go through in that # of miles, they are pretty amazing aren't they?
Hayk
09-07-12 10:26 PM
