Exhaust pipe replacement - dry or wet fit?
I am going to replace the exhaust pipe that has a flexible section. I got the OEM fit pipe from RockAuto along with seals for both ends. My question is do I dry fit the seals (hope the compress will force the seals to seal) or wet fit the seals with some high-temp silicon sealant before putting them on. If wet fit, what type sealant to use for the best?
Thank you.
Thank you.
Lexus exhaust that I worked on was on a GS. If I recall correctly, the gasket came in plastic wrap pre doped.
I dont know if RX gasket comes the same way.
Salim
Salim
The ring seals that I ordered on RochAuto for the Walker-brand pipe have thin metal sheet holding the seal materials for which I cannot tell what it is by just looking at it. But they are dry for sure.
(How do I insert pictures in this post? I clicked on the Insert Image icon ans was asked to provide URL instead of allowing me to browse for a picture file.)
Super Moderator
2. Click on Manage Attachments and then window will open as shown
OK, the picture of the seals is in the post after submit.
So I guess the conclussion based on the inputs is that these dry seals are compression-sealed and there is no need to put additional wet sealant on them. Is this correct?
stevelifts
02-08-17 01:24 PM
