sensor codes on RX300
Can someone help with information on CEL lights codes for 2000 RX300? Have codes - P0125, P1135, P0171, P1130.
I seen a previous post that the P1135, P0125 and P1130 probably has to do with the Air/Fuel sensor on the exaust manifold (probably the back one ?). Does anyone have an idea on the P0171. Runs great most of the time, occationally will have a problem with running sluggish and bad fuel economy, run injector cleaner and clears up, but now I'm getting codes.
Any help will be appreciated.
Here is a good source for information on DTC's. It should take you to the "Lexus specific" page and then when you're done there you can click on the top of that page on "generic DTC's" (P0XXX) to find the P0125 & P0171. Whenever a line is "blue" you can click on that to take you to a diagnosis and repair for that code. If you need more info, come on back.
Sorry Koyote, I copied the link and then forgot to post it. By the way, the Denso #'s for the sensors is 234-9009. They are both the same (R&L)
http://www.obd-codes.com/trouble_codes/lexus/
hksimpson
RX - 1st Gen (1999-2003)
11-07-06 05:46 PM
