Warning Buzzer
Warning Buzzer
How do I disconnect the warning buzzer? The buzzer turns on while making normal right and left turns and turns off when the wheel is back to center. It's tempremental, sometimes it does and sometimes it doesn't. But it's terribly annoying when it does. 2001 RX300
Please Help!
Please Help!
The warning chime/buzzer activating while you are in motion and turning the wheel usually indicates the VSC is activating. Does the VSC light come on? If it is constantly doing this, then either you drive like a madman or constantly in low-traction conditions (ie, ice). If neither of the above is true, you need to get the vehicle checked out becasue it could be leading to an even worse problem.
Does your CEL come on while driving?
Warning Buzzer
The car was bought at auction and is an R-title. After being rebuilt the VSC was disabled. The fuse is out, but i have it. Trust me, i drive like an old man. Do you think the replacment of the fuse will fix?
duby1
12-29-09 07:10 PM
