Rear hatch lock wont open
I worked fine two days ago.. but its been cold here lately..and now my back hatch wont open... sure sounds like its unlocking.. but it doesnt open.... anyone had a similar problem with the rear hatch... maybe its something easy to fix???
Cheers
Cheers
Early RX models had a flaw in the rear hatch locking mechanism.
Since you did not uncover it earlier, it very well could be some other issue .. like frozen mechanism (wait for warm day) or some object jammed in the catch.
Salim
Salim
Well it was well above freezing today...and now that i think about it... it was working before when it was below freezing... when i click the unlock on my keyless.. it sounds like its unlocking inside the rear hatch.. but when i press on the button to open the hatch.. it goes in.. but doesnt release the latch..... Mine is a 99 model rx so i assume it was and early model... also the guy i purchased the car from mentioned he had worked on the rear hatch as it was sticking....
What was the problem with them... maybe its something i can fix myself..
Cheers.
Cheers.
Cheers.
Cheers.
https://www.clublexus.com/forums/rx-...ear-hatch.html
https://www.clublexus.com/forums/rx-...tch-stuck.html
i have had similiar issue for many years-cold/warm. In my case, the handle in the tailgate gets stuck in a closed position when you squeeze it to open and lift it. you then close the latch and lock it with the remote, the handle stays in the same open position and wont open again despite hearing clicks. to fix, manualy push the handle back to original position (un squeezed) and then click the remote to unlock. it should then release the latch.
