Power window
Power window
RX300 2003
Car was washed and left out in the 15 degree cold weather
Tried to put down drivers window
It stuck for a second then went down half way
Now will only go down that far
Try running it up (you don't say, but I'm assuming it will go up) and HOLD the switch for about 4 seconds to see if it will reset itself. That is the normal procedure for a "reset". It might work.
^^ there is nothing to reset by opening up the door. Hope it was not an expensive lesson.
Use the search feature and or the user manual.
Salim
Salim
Schuss8899
05-08-11 05:44 PM
