Couple Newbie Questions
The Button that says PWR/ECT/SNOW... i notice it rockers to three selections.. but only one makes the light appear... i assume this is Electronically Control Traction.... But just wanna make sure.... does this effect gas milage?
Also what exactly is the Overdrive do... Ive also drove with it on... until the other day i accidently pressed it to off and the light came on the dash... not exactly sure what overdrive does...and if i should be using it....
my last question involves the 12v cigarette lighter.. I have a few things id like to run off this cigarette lighter and id even maybe like to run them hardwired... mostly ipod adapter, and adapter for nintendo wii.. how exactly is the best way to go about finding a key turn 12v power..and also hard wiring the 2-3 car adapters while hopefully still maintaining the cigarette light for the occasional weird thing...
Thanks in advance for any help..
Cheers
Cheers
Cheers
Cheers
ECT stands for Electronically Controlled Transmission
Center mode is normal driving (best MPG)
PWR is sort of the SPORT mode (faster shifts, higher shift points, which will lower your MPG)
SNOW will start you in 2nd gear to reduce wheel spin in snow/ice conditions
Overdrive button:
Turning off the overdrive button keeps the tranny from shifting into 4th gear (this is mainly useful when towing, especially up hills).
Lighter power:
You can tap into the power on the back side of the lighter socket, but if you pull too much power you risk blowing the fuse. (IIRC it has a dedicated 15amp fuse, which is a fair amount of power for low voltage devices)
Best advice I can give is ..
Get yourself an owners manual and read it. Lexus used to give complementary copies ... check Lexus.com
Salim
Salim
Do not tap into the cigarette lighter this is was designed to light a cigarette not power the whole car. Go buy yourself a a fog light wiring kit with a relay and fuse that you can mount directly to the battery this way if you blow up anything it isn't your car. They cost about $20 for a kit and you can run 1000w off them and you can switch them off and won't stay on when ignition is on if you wire up ignition wire as well. If you must have cigarette sockets wire one each to the ends that way you will have 2 more you can expand as much as you want.
well i dont think i need cigarette sockets.. im sure i could strip the car adapters and hard wire them in.... i just bought myself an 8" tablet media player ( xvid,mkv,h264,avi etc) that im going to mount upfront and hook into my rear monitors... i also wanna have the wii adapter, and my siruis radio adapter.... is it a better idea to wire cigarette sockets..and plug these adapters in regularly... or could i hard wire these adapters directly to the foglight kit as you were talking about???
Id be trying to power like 4 things that all come with car adapters now..
Cheers
Cheers
raniea2
06-20-13 12:12 PM
fireballs gs400
06-17-03 11:55 AM
