RX300 2000 Check Engine & VSC
Hello
I had rx 300 2000, today its light on Check engine (
) with "Check" and VSC light
what I have to do?
I check fuel tank cap and it is closed ok, is there any other problem? or it must be problem in engine![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
thanks
![](http://image.hondatuningmagazine.com/f/10319046+w750+st0/htup_0807_01_z+honda_check_engine_light_aka_mil_cel_or_idiot_light.jpg)
what I have to do?
thanks
To understand what is wrong you need to connect OBdII reader to the port below the steering wheel.
If you dont have one, then have it complimentary read at AutoZone and other places.
Post the code here and some one will let you know what it means.
Usually, I would read and note the code and clear it (some can be cleared by disconnecting the battery and the reader can clear it without loosing other presets).
On the next onset of the CEL, I would read and if the error is the same, only then look for what is causing the error.
Salim
Salim
Lexmex
RX - 1st Gen (1999-2003)
23
11-10-18 09:30 PM
