drivers side passenger door wiring diagram
Hi,
I have a 2003 RX 300 and I am looking for the drivers side passenger wiring diagram so I can decide what two wires are function the door lock. Anyone have this info.
Thanks in advance
Paul
Thanks in advance
Paul
There are two sets of wires to the actuator. One is the door ajar and the other is the door lock.
Salim
Salim
Pop the door panel off and lower left hand side you'll see a Black(i believe) 6 pin connector.
Wires you want to look for are Light Blue/Yellow tracer and Light Blue/Red tracer. They should be next to each other as i remember.
These 2 wires are grounded. When you flick the switch to lock it, the door lock ecu sends power to the LB/red.
When flick to the un-lock, ecu sends power to LB/yellow.
Hope this helps. Send me a cookie later.
ezduzit
RX - 1st Gen (1999-2003)
07-13-16 05:20 PM
