Bent front end!
They are cam bolts that rotate to position the strut in or out a little:
http://www.drivewire.com/vehicle/199...alignment-kit/
I don't know if these Eibachs fit the standard strut but, if not, there are bolts that do.
All fixed up!
OK,
I replaced the ball joint= slight improvement.
Went with used ebay knuckle and lower arm.
The knuckle was in fact the bent part.
I put the arm in just for good measure.
New ball joint $35.
Used Knuckle $ 90.
Used Arm $75.
Local install (not dealer) $300.
Driving the car without veering to the right, priceless.
Thanks for the help guys,
John
New ball joint $35.
Used Knuckle $ 90.
Used Arm $75.
John
