Rear rotors grinding, needs any help!!!
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Just replaced the rear pads and rotors on my 01 RX300 and took it for a test when I notice hearing alot of grinding and smoke coming from the rear tires. Like the pads are engaging on the rotors the whole time. Even when on drive, the car would not roll. I did everything right, i believe. Is this normal??? Any input would be great and highly appreciated.
If you have a FWD, you should ensure the rear wheels should spin freely before jacking the wheel down.
All parts should have assembled without forcing any part. Disassemble and put it back. Check both wheels and if one spins free, then use it as a reference to fix the other.
You mentioned .. replacing the rotor. So make sure, the parking brake mechanism is not dragging.
Salim
the rear wheels both spin freely and i triple checked that everything was ok. My concerns were when i pulled over to check them, there was smoke coming from the rotors, and the brake pads grinding on the rotor. I did have trouble removing the driver side rotor but both rotors over heated and smoked. I'll do another inspection tomorrow but if there's any other input, that's be great. Thank you.
=D Ahh i haven't. I must've forgotten to do that. With the rainy weather coming, i'm gonna have to wait until the weather get's better. Let's hope that be it. Also, the heat from the pads left the rotors discolored around the outer hub where the brake drums are under and also on the disc's itself. It's like a gold or copper color. I'm guessing it's from all the friction from the pads engaging the rotors as i was taking it for a test.
When you put the wheel on and torque the lug bolts, the disc (front and rear) gets adjusted. I always take the opportunity to flush out the fluid. Do that if you have not done so, specially now that the slave pistons have been pushed back.
Salim
Gonna get started on it in an hour. Two main things i'm gonna check for are the slide pins and if the caliper piston is bedded in. I'll let you guys know how it goes. Thanks for your inputs!
So the slide pins were seized up and was pretty much dried up. No lube on it at all. Went ahead and lube it with what the guy at my local auto store recommends. Another thing i find strange were the grinding noise didnt come from the pads dragging, it was coming from the caliper bracket rubbing on the rotors. So i disassembled everything, checked it and the rotors where effed up, both rear rotors. So now i went from replacing the old to new, the new to old, and im back where i started. Ill post up some pictures i took of the caliper bracket, rotor and pads whenever my friends forwards me them.
Salim
There are different rear rotors for FWD vs AWD. Did you possibly end up with the wrong parts? What you are describing has nothing to do with stuck caliper slides. The slides would only be a problem if you couldn't easily reassemble things and forced the caliper back on making the outside pad drag.
As far as the AWD or FWD rotors and pads, I don't know. I had my brother get me all that and he told me he got the right parts. Until I looked at the reciept it shows the guy at Kragen rung him up for 2000 rx300 pads and rear rotors. But it had nothing to do with the slide pins. Im going to attempt tp upload the pics. Not sure on how to upload them correctly.
file:///file:///C:/Users/Jim/Downloads/photo-2.JPGCfifile:///C:/Users/Jim/Downloads/photo-1.JPGle:///C:/Users/Jim/Downloads/photo.JPG:/Users/Jim/Downloads/photo-3.JPG
