Subwoofer Install Pics!!!
#61
Paddy- That is a GREAT price. It retails for $400 on Crutchfield.
To install the basslink-
You would just follow the guide I already made. Only difference is you wouldnt have to run wire to the subs separately. I had a cool idea-not sure if it would work.....but there is alot of room under the rear seats....more than it looks. I wonder if it would be possible to wire one or two of those under the rear seats. That would be a tight install! Just wondering guess I should check the measurements.
Also- Everyone check out the ebay auctions. There are Headrest TVs specifically for the RX selling. They are already in the headrest...looks really good. $650 for two screens already installed...dont quote me on that.
#63
Absolutely. I was just saying the seat thing as an idea. You can run all wires without removing the rear seats. You would have to remove the front seat to get to the sub. It is very easy though.
#65
Originally posted by Paddy Wagon
Basslink...Couldn't you just run a line from the stock sub through a converter? Don't have to mess with the stock amp or the back seats.
Unless there is something wrong the units, I'd say you found a kick-a** bargain.
#66
I just looked thru online discounters...Can even get a 3 year extended warranty for $19.95 more
http://www.dealtime.com/DealSearch/G...&PrdId=2106034
http://www.streetprices.com/Electron.../SP727775.html
http://www.bizrate.com/marketplace/s..._id=200&sort=5
#67
I think you need a converter. I opened up the stock sub and there is no amp inside which means that the input is already amplified. If it were too strong a signal you could blow the Basslink. You might could get by, but to be on the safe side I would go ahead and spend the $23, if for nothing else peace of mind.
I would imagine you want to take the stock sub out anyway (why have a useless sub under there), and to do this you have to remove the seat. So since you have to do that anyways, while your under there might as well go ahead and throw a hi-low filter in. At least in my opinion you should.
#68
Bangin install dude! I'd be motivated to do the same but...mom probably won't appreciate the bass as much as I would
For everyone thinking of Infinity Kappa's you should alos check out the Audiomobile MASS series...I know you probably haven't heard of that brand but for the past few years these things have exploded onto the scene. If you check the forums over on www.sounddomain.com (which by the way is a fanstastic car audio forum) you will see that more then a a handfull of people have been replacing TWO 12" Infinity Kappa Perfects w/ ONE Audiomobile MASS 2012 and it has hit much harder and cleaner w/ the same amount of power being fed to those two Infinity's! :eek: Not knockin those subs because those were gonna be in my trunk at one time until I heard about the other ones...now I have neither cuz I ran out of money, but hey...what are ya gonna do They usually feed the pair or the one sub w/ a JBL Powervalve 1200.1 which puts out about 1375w RMS and that one sub will hold all that power by itself all day long...
For more info on those check out www.audiomobileinc.com
But yeah, keep us updated on future progress because the walk-through was fantastic
#69
Thanks for the props
Having Infinitys is starting to kinda be a tradition of mine, so I doubt I will ever have a chance to put anything else in....but I will pass the word along to friends and the like about the other brand. Thanks for the input!
#72
RX 300 & 350Z Guru
You wouldn't have the frequencty response with the OEM sub that you can achieve with a 10" or 12" sub. It's just not big enough to produce the low - booming - frequencies that can bring a smile while listening to your Jazz, Rock, Pop, etc
#73
Ok folks...
I have an old Audio Source Real-Time Analyzer (RTA) in a box somewhere (I use to do high-end home audio in another lifetime). I probably will be adding a subwoofer, but I want to see what the current frequency response is in the cabin. If my hunch is correct, adding a BassLink without removing the stock subwoofer will be kick-a**. The stock woofer can fill in the "high" low-end and the basslink can fill in the "low" low-end. Overall this should be great cuz it will lessen the strain on all the other components.
The only tricky part is finding the ideal crossover point for the Basslink... that's where the RTA comes in. I also have to pick up a calibrated pink-noise source on CD in order to complete the experiment.
I'll post at least an octave repsonse graph when I'm done. Should be interesting.
#75
Originally posted by LexRX
I went to Circuit City today and see that they are selling the Infinity Basslink now for $299.
