My Turn... help me out with my install
Old 08-22-02 | 05:25 AM
Shonuff's Avatar
Shonuff
clips that need to be pryed on
Old 08-22-02 | 05:26 AM
Shonuff's Avatar
Shonuff
top one
Old 08-22-02 | 05:27 AM
Shonuff's Avatar
Shonuff
then pull it out
Old 08-22-02 | 05:28 AM
Shonuff's Avatar
Shonuff
another problem are....be carefull on this one......have to pry on the right area without too much pressure
Shonuff's Avatar
Shonuff
like this
Old 08-22-02 | 05:39 AM
Shonuff's Avatar
Shonuff
speakers. see how the blue adapter is molded to the factory speaker?? you gotta make an adaptere like that out of mdf so your aftermarket speakers will fit.
Old 08-22-02 | 05:42 AM
Shonuff's Avatar
Shonuff
same on the fronts
Old 08-22-02 | 05:43 AM
Shonuff's Avatar
Shonuff
tweeters pulled out with the infinity's installed
Old 08-22-02 | 05:46 AM
spinteews's Avatar
spinteews
YOUR THE MAN SHO!!!!!!!!!!! keep it up man, your guiding me thru it all haha, its late now and the rx3 is left at buddys house, but tomorrow, we'll continue with my adventure in installing =)
thanks guys
Old 08-22-02 | 05:50 AM
Shonuff's Avatar
Shonuff
if you run into any more probs let me know.....you got my number.
Old 08-22-02 | 06:00 AM
spinteews's Avatar
spinteews
No prob man, just expect my call and keep your phone on
Old 08-22-02 | 02:24 PM
RX300TC's Avatar
RX300TC
Default Question regarding replacement tweeters
For the folks that have replaced the front component speakers with aftermarket (like Infinitys):
Do you just plug in the the aftermarkets and use as is, or do you splice in the crossover that comes with the new speakers? If so, where do you mount it and how?
Thanks.
Old 08-22-02 | 03:15 PM
Shonuff's Avatar
Shonuff
tc: we ran new wires to all of my speakers (replaced front/rear/tweeters) ran wires from the new amp and used the new crossovers that came with the infinitys. we mounted them in the kick panel area on the driver and passenger sides. also my aftermarket head unit (replaced that as well) has a hi pass filter on it.
Old 08-22-02 | 03:49 PM
RX300TC's Avatar
RX300TC
Ahhh.... my mistake shonuff (but thanks for the clear repsonse), what I'm interested in specifically is folks who just replaced the speakers and not the head unit (I have Nav so replacing the OEM head is not really desirable to me)
I'm leaning towards Infinitis or even Dynaudios if budget permits.
So anyone else just replace the speakers?
Old 08-22-02 | 05:02 PM
Shonuff's Avatar
Shonuff
just replacing the factory speakers should be feasible.......i do not think you would have a problem just switching out the speakers and using the stock wiring.
the factory speakers should have a crossover on them already but i imagine you could just run them in line. i believe the line splits in the door to run to the tweets.........but i have to check on that again
