Remanufactured Tranny 1 day old, now A/F Sensor??
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Check engine light/VCS came on shortly after picking up car which had remanufactured transmission put in by lexus for 3500. Dealer ran code scan and just called now wants $292 to replace air fuel ratio sensor. Everything screams for this to be related to the recent work done as I noticed low power right away driving car away from shop and within 6hrs the Check Engine/VSC lights were lit up. I cant find any solid correlation online to prove.
I had however, read about problems with replaced tranny's not always syncing with a cars computer, of which the technician who test drove car with me this morning also agreed and I thought this might be problem.
I would like to fight this charge and demand they fix as related to recent transmission work but I would like any comments/advice if I am on the right track or if bad timing has kicked me in the pants again!
Thanks
John
Thanks
John
Thanks
John
Thanks
John
Which A/F sensor is it?
Still too much IMO but yea I have heard worse.
Yea I will complain and see what happens. I didnt get the codes yet from dealer but looks like the part itself is at cost around $160 and they said they could install in 30min so padding their end obviously on both
If you wanted to, you can go to Autozone or another auto parts store that does free OBDII code reads. They do a print out for you as well. Then, you might have more knowledge to see what angle to address it.
BTW, the front A/F sensor doesn't look too hard to replace... if that is it. Autozone also has free rental tools to remove them... which are very handy.
I know, though. It seems they should have given you your car back in top shape. It's a Lexus dealer!![Angry](https://www.clublexus.com/forums/images/smilies/anger.gif)
Good luck with it.
Good luck with it.
Depending on which sensor is faulting you might be able to clean it or (if you need to) replace it yourself... But you need to know which one is faulting. Most of the sensors are easy to replace. As a courtesy after the work they did on your car, they should be happy to translate the error code for you.
Mine was the Mass Airflow Sensor (MAFS) but yours might be different - from your post it's hard to tell which sensor it is. The Toyota dealer said they will only replace the MAFS with new, but was helpful letting me know which sensor was faulting after they serviced my car. The MAFS it is easily serviceable for any DIY'er. I was ready to order a brand new one online (the car's earned a new sensor after 13 years), but I figured I might as well try cleaning the sensor element first (with the help of some instructions shared on forums). A couple screws, unplugging the connector (hardest part), a can of CRC MAFS cleaner from the NAPA store, a couple careful shpritzes and reinstallation again, just a few screws. Then I cleaned the battery terminals (which also served the purpose of resetting the Check Engine Light & codes) and it's been about 7000 miles, the car's been running great again and no trouble codes or CEL.
Let us know what happens or what you find out...
That's a good call, LA4Mead, on the MAF Sensor.
Exit74, at least check the connections to the MAF sensor and clean it. Very simple job. And also all the connections/wiring to each of the A/F sensors. It is possible, that the mechanics didn't connect them properly after the work. (I know, slim chance...) But worth a look.
I once had low power and codes on another vehicle, and had left the MAF sensor disconnected, accidently. It reverted to a more basic air flow sensing mode, but didn't run well.
lexlovgs
05-01-07 10:35 AM
