Cruise control troubles
Old 05-02-11, 08:26 AM
Lexmex
Super Moderator
Lexmex's Avatar
To add it to our DIY links
Go here, https://www.clublexus.com/forums/rx-...x300-diys.html
And then in the quick reply, paste this link,
https://www.clublexus.com/forums/rx-...-troubles.html
Old 05-02-11, 10:33 AM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
Originally Posted by Boger
Like what? I thought I just posted that above... or you mean the serial number of the motor?
The link in the DIY: How can I add it?
Source or model number of the $1.95 motor.
Salim
Old 09-07-11, 12:41 PM
Xtom73G
Xtom73G's Avatar
As with computer issues, first check to see if it is plugged in. LOL. Mine would accept and hold a speed, but upon brake cancelling, or moving the stalk, it would always cancel. So I found the module in the engine compartment, noted the electrical connector on it, pressed the release tab and unplugged it. Cleaned it, squirted electro repair grease into each pin hole, wiped it clean, re-plugged it in, and voila! All cruise functions now work perfectly. Cost, 98 cents.
Old 09-10-11, 03:54 PM
Xtom73G
Xtom73G's Avatar
Others with problem; find the under hood (bonnet) cruise module. Carefully pull the electrical plug free by pressing the release tab. Squirt electro-conductive repair grease into the plug holes, press in with finger, repeat, then wipe clean. Plug it back in, all may now be good.
Old 05-09-16, 08:40 AM
av8rga
av8rga's Avatar
Default What pins to test actuator?
Hi, just wondering what pins are used to test the actuator? And I presume 12 volts? I looked and could not find a diagram. Thanks for any help
Tim
[QUOTE=Boger;6349107]Just 2 update y'll on the solution:
The actuator was the issue, it didn't actuate ....
I tested it using the method described in the workshop manual (attaching the battery to the 4 connection of the actuator), but nothing happend.
So I took the actuator out of the car to have a closer look.
Old 05-24-16, 10:48 AM
av8rga
av8rga's Avatar
Found it by Google RX300 diagnostic pdf
Neverdone
04-27-20 06:44 PM
Stoyamajello
SC- 1st Gen (1992-2000)
05-07-12 11:23 AM
pinoyballa
08-31-09 03:50 PM
royaladd
05-15-09 07:44 AM
Mike_TX
07-17-06 03:25 PM
Quick Reply: Cruise control troubles
