Sunroof Hail Damage
Sunroof Hail Damage
Daughter's car got pummeled in a recent hail storm. Sunroof is shattered. I am wondering if anyone on the forum has had to replace that part of the sunroof. If so I would like know a ballpark cost for parts and labor. Anyone attempted as a DIY job?
Is there any reason I should go to a dealer on this, or would an automative glass shop be normally able to handle this job?
Thanks,
Russ - East Tennessee
Thanks,
Thanks,
Thanks,
If somehow there's no insurance, I would suggest locating a used one in a wrecking yard. It might be a little more than you could handle to install, unless you're at least mechanically experienced.
As you may have guessed, with widespread storm damage the insurance carriers are totally covered up right now and I am 1000 miles away from her and the car. I was just trying to get a better understanding of what my/her options are going to be, and you have been helpful. I don't have the policy in front of me, but we are State Farm and I carry collision but at a high $2000 deductible. I am sure there is comprehensive and all the other normal coverages. Our family has had only one claim in 40 years, so very short on experience of how it all works. I must say what you say about comprehensive sounds very good. Yes, there is body damage in the way of dings and pretty big dents she says from the hail. She and a friend quickly covered the damaged sunroof with plastic and she reports just a little dampness on the sliding panel under the sunroof. To add to the confusion she called the next day with a long list of things that no longer worked normally, locks, lights, A/C, etc. and then the following day to say it would no longer start - or turn over for that matter.
I'll follow up with a post of how this all works out when I get back home in about a month. Thanks for replies. Russ
Read the policy. I n case of breach, I think it is reasonable that you get the repairs done after notifying the insurance company. Lot of repair places work with the insurance companies and the work in many places gets in the queue based on repair shops when a calamity affects a large population.
Salim
A gazillion different insurance companies and as many different policies because almost every state has different rules the companies have to abide by. I have NEVER carried a comprehensive deductible near as high as collision. I'm sure I have never carried a comp. ded. any higher than $250. Comp. is GENERALLY pretty cheap, no reason to carry a high ded. there because you don't save that much money over a low ded. and most comp. claims are out of your control (unlike, say collision) I personally have never carried HIGH ded. on any of the vehicle ins. People want to save money so they get a high ded. and then when they have a loss, they cry the blues. Can't have it both ways. I prefer to not have losses and therefore end up with very low rates with a top notch insurance co. (much better than State Farm, I spent 30+ years in the body business, I should know)
Thanks,
Thanks,
An automotive glass shop MAY be able to do the sunroof but it would be better if done by a sunroof shop, or the dealer. I used to be in the sunroof business and they can be a little tricky, requires someone who has some experience to do it right! Good Luck!
Hi Keith,
I am advised by my agent that my deductible for collision is the same for comprehensive ( $2000). Although no one here has suggested the cost for a sunroof glass replacement I am thinking I will go ahead and have the car looked at by the adjuster and see what is proposed. I hope doing that does not commit me to anything. I was also advised that the claim, should I follow through, will not be considered as an "at fault" and will not contribute to any changes in my rates. I feel fairly sure when all the other items in addition to the glass - dents and no start - are factored in, the estimate will exceed the deductible.
I was initially trying to decide if it was wise to invest beyond the cost of the glass sunroof in a car we may well drive until its normal depreciation has reached a very low value. I am still weeks away from getting back home to the area. Sunroof is all sealed up with sheeting and interior is water tight for now.
I'll let you all know what happens next. Russ
If you have sheet metal damage to the hood and roof, the repair cost for those is going to exceed the sun-roof repair cost. Compare the total cost with blue book value (just as a reference).
Also if you go the adjuster, you are not obligated to follow through with the repairs, but the incident gets recorded and becomes a history of the vehicle.
Salim
Salim
By the way, he did respond, are you happy now?
Thought I would bring this thread up to date a little.
Today, after replacing the battery, I got the car to start and took it to the disaster claims area State Farm had set up to deal with all the hail damage. Much to my surprise and disappointment, they totaled the 2001 RX300. I had recently put high dollar Michelin tires and a "new" transmission in the car. The hail damage is cosmetic except for the puntured moon roof ( no water damage inside ). I really hate to go shopping for a replacement car at this time. I have been told that I would have the option to keep the car and the settlement would be the retail value minus salvage value minus my deductable. If I go that route the car would no longer be eligible for comprehesnive insurance and would have a salvage title. Since our plans were to keep it until it was no longer servicable, maybe that is an option I should consider. I would have to find a glass shop or body shop to fix the sunroof. After that if there was money remaining I could look into some of the paintless dent removal folks that are working in the area.
If anyone reading this has been through something similar, I would appreciate any knowledge you can pass along. Thanks, Russ
I would pull it out myself and replace it with one from a wreck. It is only bolted on like any other window i have seen sunroofs installed i would give it a go rather than drop 2k on insurance.
