ok put the new knock sensors and harness in. only took me about 1:20 start to finish. now i have a p1150p code but i pulled the batt cable. ill drive it tomorrow to see if the pending code comes back.
Wow ... that is speedy. The coolant drain and fill took me a good portion of an hour.
really? i just pull the petcock valve and take the cap off then start on something else.
im back from miami about 1k miles total this weekend and still running great.
If you have discovered a way to replace the knock sensors in 1hour 20mins, please post. If there is a typo please correct. The main purpose of the Forum is to help each other and learn from each other.
