WTF 15 codes???
my 2000 rx hase 200k on it and its throwing these codes
where to start?
p0300 Random Misfire,
p0301 Cylinder #1 Misfire,
p0302 Cylinder #2 Misfire,
p0303 Cylinder #3 Misfire,
p0304 Cylinder #4 Misfire,
p0305 Cylinder #5 Misfire,
p0306 Cylinder #6 Misfire,
p0325 Knock Sensor Circuit Malfunction,
p0330 Knock Sensor 2 Circuit Malfunction (Bank 2),
p1130 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1),
p1135 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1),
p1150 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1),
p1351 VVT Sensor Circuit Malfunction (Bank 2),
p1354 VVT System Malfunction (Bank 2)
p0171 System to lean (bank1)
where to start?
One fault (eg bad coil) can sometimes cause a number of codes. I had one bad coil which was throwing 5 "bad coil" codes. I have a cheap code reader - the dealer has the Toyota Techstream reader which may be able to discriminate/diagnose better.
Clear them out and see what pops back up. If you have a bad coil, the engine will be misfiring badly. If you can't feel it misfiring (shaking/vibrating/ loss of power), you probably don't have any bad coils.
o2 is in now i just have p0325 Knock Sensor Circuit Malfunction,
need to find the resistance spec of the knock sensors and harness so i can test them. anyone know?
Salim
the battery is disconnected now cause i removed the intake to get to the knock sensors and harness. just waiting for someone to let me know how to test the harness and sensors so i can order what new parts i need and put her back together.
ok put the new knock sensors and harness in. only took me about 1:20 start to finish. now i have a p1150p code but i pulled the batt cable. ill drive it tomorrow to see if the pending code comes back.
