Led turn signal mirror cover
Switch removed from door cover.
Door panel need to remove. Pry door switch by flat screw drivers. Here is the link for removal: https://www.clublexus.com/forums/rx-...moval-diy.html
Solder wires.
Solder the wire connections and taped. Remove the led mirror cover 3m tape and sit on the top of old cover nice and smoothly. Install the mirror glass back by soft press on the white plastic frame.
Run wire through door cable insulator to door.
Behind the glove box locate the flasher connected red wire (which already run) and run through the door cable insulator at the right with black ground wire to the door. I use a body trim bolts as a ground and works.
Remove the speaker before you run the wire to the door. It will make easy and i used a hanger for run the wire. Here you will see the ground wire and speaker.
